Greenacre cs2 controller
Peeeg
29
Hello first post I was looking for a rear hub kit had a das-kit 28" 250w 36v which was brilliant was looking for another one however a broken greenacre cs2 has fallen into my lap; all appears well however it appears to be operating in a kind of limp mode it's crawling along when I use the throttle I was told it needs a new controller but surprised to find the wheel turns at all with a broken controller; looking for a manual or anything to run through some diagnostic checks is the controller in the hub or built into the battery holder ? Many thanks
3,993
4mph with the throttle is normal because that's all you're allowed to have legally. Does the pedal assist work?
Peeeg
29
Thanks for the reply, no the PAS is kaput, im going to put the issue as a separate thread as its a tale of woe
3,993
If you have the same LCD as this one, you can adjust the throttle. If you have a different control panel, show us a photo. This vid was made by forum member
Jips1971
Reactions: Peeeg
