Hi all, great forum but first time posting.
I have a Giant Twist lite that was making some bad noises from the front hub motor.
Stripped it all down to find about 20ml of water that had ingresed the motor housing and subsequently distroyed the motor bearings.
Now I've searched high and low and parts seem to be quite scarce for this bike. Found a motor in Norway and a site in Holland that has a few bits.
Basically I wondered if anyone else had replaced the bearings inside the motor itself on this bike?
It's the bearings inside the motor that I need to replace. There's two inside one at the top and bottom of the shaft.
The bearing at the top of the shaft I can just read the numbers (69027 I think) shown in the first pics.
However the bearing at the bottom was completely distroyed as you can see in the pictures.
Does anyone know if replacement bearings can be sourced or perhaps a replacement motor? Shaft length is 145mm.
Giant are useless btw.
I can upload more pics if anyone is interested.
