Giant Twist Express
halfmedley
155
Not sure if this machine has been been mentioned on the Forum already, but it's due out next month apparently. Don't know too much about it unfortunately, other than it looks like a standard Giant front hub job with 'panier' style batteries.
john
531
Manchester
Why do companies so often choose to put batteries on the rear rack when adding to a standard bike? The frame main triangle is a much better place for the battery.
halfmedley
155
I guess it's an easy option for Giant, in that they don't have to make any frame/geometry modifications and can use one of their standard frames.
The frame on the Express looks like one of their sporty hybrid models (CRS?), than the previous Twists (1.0 etc), which have/had a more 'sit upright' geometry.
30,844
I couldn't agree more John, but Giant have been prone to some very odd decisions over the years. These twin batteries severely compromise the pannier options on the new Twist, a bit silly on a utility bike.
30,844
It's the first I've heard of it, but hardly surprising since the new Twist has been given a very firm thumbs down on it's slowness.
I'm fearful of the outcome though, since A to B only achieved just over 40 miles on those twin 26 volt 10 Ah lithium batteries, and more power could shorten that still further.
Maybe they've reverted to the 36 volts that motor had in the better performing Suede, though that's unlikely given the battery positions.
halfmedley
155
There's no mention of the voltage in the article. If I could figure out how to paste an image into a message, I could scan the photo and post it on here. How do I do that? When I click the insert image icon all I get is a message asking for a URL...
30,844
Two ways, but number two will be best for you:
1) If you have somewhere to post pictures online like flickr.com or similar, you can display those here in this way. Just go to your web image, right click it and select Copy Image Location from the context menu, or if that doesn't show, click Properties on the context menu that appears and highlight and copy the URL there on the Properties page. Then return to the Reply box here, position the cursor below the text where you want the photo to appear and click the yellow mountain scene icon above. You'll get a box to paste in the link and ok it.
Then submit the reply and your photo will appear.
2) Click the paper clip button above the reply box and have a look at the photo size rules there. Then make sure the picture conforms to those rules, and preferably is sized to 800 x 600 pixels or less to avoid the huge oversize things that some insist on posting.
If all's well, click the paperclip again and browse to your image, then upload it. Then click the paperclip again and you'll see the image name, click on that and it will be attached at the point of your cursor in the text box.
30,844
No problem! That's the same lithium batteries and mounting, so it looks like a controller change to boost things. That will make the range even less impressive for twin 10 Ah batteries, probably less than a Wisper 905se with it's one 14 Ah battery, and still slower than that I'll bet.
Poor Giant, their eighth e-bike design and still they are floundering around. :(
fishingpaul
874
86
why start knocking it before it is even released,they are a big brand selling their bikes at reasonable prices,at least parts on the giant bikes dont start working loose after a couple of hundred miles,they may not be the fastest but generally climb well (if a little slowly) and are usually reliable,the sanyo motor climbed slowly but surely but was classed as a poor hill climber by a to b,i found it quite a good climber even after a sakura,( which had the same motor as a powabike), the only downside was the drag from the motor when riding without power as with many hub motors.negative comments on bikes like these,can make people look for far better electric bikes which do not yet exist,there may be slightly better performing bikes but only by a small margin,often compromising extra speed for poor hillclimbing and not riding like a normal bike,or climbing well but rather slowly.
30,844
Except that far better bikes do exist, and at reasonable prices.
That's why I knock it, just as I've praised them when they have got it right.
We're all entitled to our opinion and I'll express mine as I wish and when and where I wish.
JohnInStockie
1,048
Stockport, SK7
Does anyone have any more details on this bike (weight, motor power, frame sizes available, e.t.c.)
John
30,844
John
Everything except the frame style, weight, size is covered in A to B issue 58, February 2007 John. It's a medium powered motor of some 400 watts peak which appeared years ago in the USA and was long discontinued when Giant picked it up from Sanyo who made it for the US Birkestrand Corporation originally. Contrary to what Paul posted above, A to B said it climbed quite well, but they've reported at various times on how slow it is and that the range of a little over 40 miles on two 10 Ah batteries is nowhere near the claims for it. The motor is very high drag for pedalling without power since it has no freewheel. It's supposed to regenerate power, but unlike the BionX system, that doesn't seem to work to any measurable extent.
A to B's website summary says that its "dreary", and having ridden it, I endorse what they say, hence my remarks above. In it's original form as the Giant Suede at £600 it was a good buy, although somewhat spoilt by poor battery quality, but after revamp as the Twist 1 at around £1400, it's anything but a good buy, and a frame change is hardly going to rescue it.
jac
315
hi i have just been looking at some photos of the express and it looks like a different motor to the twist although i wouldent say that definitley as photos not to clear
jim
Bikerbob
215
Isle of Man
The new Twist Express LOOKS a very different bike than the one reviewed in AtoB issue 58. A better looking frame style and a more 'sporty' image with derailleur rather than hub gears. I assume we don't yet know the details on weight and price. I take flecc's point that the fact that it apparently continues the same battery/motor setup isn't at all promising. However Giant's network of local dealers is a big plus and as my Giant Suede continues to battle gamely on I do wish Giant well in producing a worthwhile replacement. This probably isn't it, but I'd like to see how the new bike performs before we write it off - maybe Giant have managed some improvements. Probably an expression of hope over reality though!
30,844
jim
It is the same one Jim, the same controller unit and batteries, and exactly the same front wheel detachable connector for the Sanyo made motor.
With a different electric set as well as a different bike it wouldn't be the Twist any more, and Giant have always renamed for the slightest change, Suede, Argue, Twist models for example, all fundamentally the same base system.
30,844
As do I Bob, but I've followed their antics over the years and this shows no worthwhile change that I can see.
The problem is that when changing from the 36 volt Suede to the 26 volt system for the Twist, they sacrificed speed and power for range but didn't really achieve that either. In answer to the justified criticisms of the Twist's slowness they bring this out, and if they've boosted the power the range will have deteriorated further. What is really needed is a completely new start for marketing a bike at £1400, not tarting up a £600 model, though I think they aren't suited to making e-bikes and should stay out of the market while it's small.
I suspect they are mainly relying on the weight decrease to improve performance. The Step Through model is a hefty 30.1 kilos due to the twin batteries and sprung forks, so this will be around 26 kilos to 27 kilos, still no lightweight.
halfmedley
155
It's puzzling how the company that brought us the much admired Lafree, should seem to be so 'off-the-pace', though maybe the bike will surprise us. Perhaps they don't have a British (i.e. hilly) market in mind, and are more focused on the low countries?
Bikerbob
215
Isle of Man
I can't agree that the likes of Giant should stay out of the market, flecc, they just need to produce better electric bikes. (I realise you meant as a temporary measure until they get it right).
I may be an extreme case, living on an island, but I'm a little reluctant to pay £1400 for a bike, plus £90 delivery, with a high risk of damage in transit, and then face transport problems if the bike has a major fault. I think similar considerations probably apply even to people in the more far flung areas of mainland UK. In the case of the last bike I bought by 'mail order' it seemed to have been laid flat on the ground while people walked over it. There were dirty boot marks all over the packaging and large holes where their boots had gone through between the bike frame. When I bought the Suede from a local dealer there was no delivery charge, they gave me a £30 discount because I'd had to wait, it was in perfect condition and well prepared when I collected it, there was a free adjustment service when it had bedded in, and I get friendly willing service when I go back to the shop. That's what larger manufacturers with big dealer networks can offer. Maybe the present economic climate will encourage them to take electric bikes seriously.
Short of that I'd like to see the present suppliers of the better elecric bikes engaging local bike shops as dealers rather than us having to buy from them direct.
