Giant e-road crank removal
Standard square taper AFAICS. What's different?
6,512
Artstu
2,420
925
I can't see the photos, but you need a smaller head on your extraction tool, some have a removable head on.
Reactions: Steve UKLSRA
Artstu
2,420
925
So it pushes inside the black nut thing that's in there?
The area the tool needs to fit into to contact the end of the square taper is smaller than the ones you're used to, SW's photo shows the size differences.
6,512
:D
Mac_user82
317
122
42
On tother bike the crank is on a splined shaft and I have the puller that gets them off easily whereas this one looks to be threaded all the way in.
Better pic of it.
i should of thought a "Park Tool cc-p44 would get that off straight away
