Hi All,
I am thinking of changing the Chain ring(s) on my E-Bike as it is quite low geared & I do more road than offroad. The front gearset is 38/28T & made by FSA. They mount to a 4 spoke drive with allen bolt/nuts. I can see various 4 spoke FSA Chain rings on the Web but will they fit the drive hub? How can I tell if compatible? On the outer chain ring I can see M11/D10.
Are there any specific E=Bike considerations i.e due to the extra torque. It also appears the outer chain ring is quite badly worn, or are they supposed to look like that? Bike has less than 200 miles on the clock! See attached photos. Expect I will need a new (Longer) chain or need to add links to make up for the extra teeth. All advice gratefully received.
