Gearing
Andy-Mat
2,214
562
78
Why do most E Bikes expect you to pedal with a cadence of an athlete to get any speed?
Maybe your controller needs properly setting up?
I have not experienced that on either of the bikes I have owned...I shall be 74 this year!!
Andy
Prefect
32
9
I like to cruise on the flat at 17/18 mph and down hill I like to exceed 35mph (if I can) but with my EBike I am pedalling like a lunatic.
I understand they are designed for puddling along the flat bits and then helping up hills but why are they geared so low?
6,516
8,533
With hub drive you can use any gearing you like.
Prefect
32
9
I suppose it all depends on how the motor is programed, if i were radiacally go to the highest gearing possible would the system still work nomally up hills then allow me to do my thing downhills?
Prefect
32
9
Hi I think all Ebikes ar emanufacured the same, my theory is that they are geared so the user can get home with a flat battery, maybe taking in a few hills, hence the very low gearing to accomodate the wieght of the bike.
My bike is currently a 2014 Kalkhoff Agattu i8HS which has Nesus 8 gears. I can go up the steepest of hills in Gear 4 (with max boost) which seems a waste of gear range. I can purchase a range of sprokets for Nexus 8 ranging from 24 to 16 my bike is factory fitted with a 21 sproket. I have not counted the chainwheel teeth.
Darren Hayward
93
47
Every ebike I've seen has a single front chainring, which limits the total gear range available. If you manufacture bikes your make a bike that will suit the most people so you can sell as many as possible. In gearing terms that would tend to be at the low end for ebike's as fit riders don't buy them.
Prefect, if you can cruise at 17/18 mph why do you need an ebike in the first place? Just curious,
Darren
Reactions: mike killay
Jonah
882
246
EX38
Change to a 16 tooth rear sprocket and you will be sorted.
Reactions: robert44
Prefect
32
9
I played squash for many years which made me fit in the right places, heart and leg muscles to be a decent cyclist. As the years pile on its the hills that are a challenge and heading into the wind. I was anti getting an ebike for a long time but now I’ve tried it I love it.?All the hills I avoided in the last few years are now taken with aplomb. I am just frustrated by the low gearing. I should think many Pedelecs are in the same boat.
Ocsid
450
271
Hampshire
They are IMO geared to suit the European pedelec market, which by law limits the assisted speed to 25 kph.
For those wishing to exceed that speed, then during that time they will not be assisted, the assistance there being simply a hill climbing aid though only where the speed is below the legal limit.
As said, these retail European e-bikes are geared to suit their market.
8,533
21 sprocket on Alfine/Nexus is a kin to using a 13/40t cassette.
The ratio's relate approx. to 40, 33, 28, 25, 21, 17, 15 & 13t sprocket sizes.
8,533
Have ordered a 16 tooth sproket, looking forward to trying out!
16t sprocket is a kin to a 10/30 cassette.
The aprrox teeth ratio's are a bit closer.
30, 25, 21, 19, 16, 13, 11, 10.
8,533
RobF
4,732
2,312
Your Nexus hub is bomb proof reliable, bit its range is not great.
Many internal gear hubs are the same, apart from the Rohloff which has a range comparable to a mountain triple.
I have one and reckon it would do what you seek.
Hardly a viable mod at £1,000, so you are better off with your sprocket change.
As a general point, you have the wrong bike for your purpose.
A sit up and beg Kalkhoff Agattu is a quality ebike, but it is not designed for barrelling along on the flat and descending like a demon.
