Not related to an e-bike, but I’m sure the question will tap into someone’s knowledge.
I’m building a titanium road bike. The photo shows the underside of the bottom bracket ( BB) back wheel dropouts at the top of the photo.
How do I get the front & rear gear mech cables around the underside of the BB? As you can see, a cable clip is welded to the underside of the BB. This clip isn’t of the type which allows the inner cable core to slide over it. There is also a tapped hole in the middle of the BB, which I thought was for attaching a Nylon slider cable guide. But the hole is directly in line with the seat tube cable guide to the front mech. I can’t work out how to get the two cables around the BB. Traditional guides do not fit.
Any ideas please?
Sent from my iPhone using Tapatalk Pro
