Hi,the situation i described in a previous post was this. Fitting a watt meter i carefully tweaked the shunt to give 17-18 amps on full.Ive ridden a couple hundred miles,with plenty of 2 mile long hill climbs at 17 amps all the way. Not once did this cause any overheating of controller or motor. Then one time i rode a mile on flat terrain,stopped.Then when i went to continue,all i got was a hum and a brief twitch from the motor. The caps are 50v ,the fets 60amp continous max.
I discovered one fet had blown. I replaced it ,then noticed a tiny black component nearby was split and surrounded by a smoke stain. Its black 2mm x 4mm ,marked Y2.Ive identified it as a ZENER DIODE. Well without much hope of it working ,i connected the battery anyway.There was a bang and the replacement FET instantly burst into flame. Fresh smoke staining around the diode apparent.
Can anyone tell me, have i pushed the controller amps too far,its 18 absolute max,usually 17 - 17.5 ?
Did the fet blow because the diode failed or vice versa ? Is the diode likely to have failed because of the increased amps,or just fatigue ?
Im trying to get an idea if replacing the diode and fet will get things going again.Or will it likely wear out again ,due to the amps being too much for it ? I like fixing things if theyre not too far gone.Its good experience. Thanks if anyone can enlighten me.
