I've recently noticed my front wheel has been a bit 'gritty' when spinning. First I adjusted the brake thinking it was rubbing then decided to check the bearings. It's the first time I've taken the front wheel apart so didn't know what to expect and I've done about 6500 miles on the bike. What I found was bearing balls sat in dirty grease so removed the ball bearings, cleaned/regreased them. I think I found the rough spinning problem though, it looks like it's caused by the nut things which tightens up onto the bearings themselves.
Can anyone tell me what this is called and where to get new ones?
