Front light using power for rear lights?
Wayners
423
94
55
Gloucester
I have a yose power kit that comes with a wired front light. Is it possible to use that to power a rear light?
Was thinking of a two into one adapter?
Guess most use a battery rear light.
3,382
If you switch it on from the control panel, it's best not to do that in case you overload the transistor that switches it on. on the other hand, if it has its own switch, it should be OK, but make sure you get a 36v light or one that can run at any voltage.
Reactions: Oldie
