front leaf motor 1000W on 26" wheel - 149euro-Paris, France
cwah
3,048
179
www.whatonlondon.co.uk
New ULTRA powerful and efficient Gearless motor custom made with higher grade laminations, wider magnet stack, high speed NSK bearings, Honey well hall sensors, more copper fill, and all out higher performance. We went through all the stops to make this motor the absolute best hub motor on the market.
This motor has the more acceleration at low end, better mid range, and more top end. Also offer this wheel professionally laced into our double wall aluminum rims with 12g spokes. Message us for details. 20", 24", 26", 700c and 28" sizes are available.
Detail:
>. Rim: 26 inch double wall Alloy ( tire: 26 × 1.5" / 1.75" / 1.95" )
>. Spoke: 12 gauge / 156mm Length × 36 pcs
>. Engine: Bldc hub motor
>>. Voltage: 48V
>>. Power: 1000W
>>. Efficiency: 90.5%
>>. Max speed: 70.9 kmh -- 44.0 mph
>>. Mechanical brake: Disk or V
>>. Cable location: shaft end , LEFT
>>. Cable length:160cm / 63"
>>. Install: spacing of 100mm fork
>>. Noise: < 60 db
>>. Surface: Black painted
>>. Net weight: 7.26kg / 16 lbs
http://www.leafbike.com/products/e-bike-hub-motor/gearless-20-24-26-700c-28-inch/newest-26-inch-48v-1000w-front-hub-motor-wheel-882.html
I bought it for a project I didn't do at the end. It has been sitting for a while now. Come grab it in paris, france.
New super low price at 149euro!!
SocoNina
7
Hello! Does it have disc brake? Do you have the rest of the kit or only the wheel?
cwah
3,048
179
Hello,
It does has disc brake. I don't have the associated controller. I do have spare controller but I don't know if they work. I can give it for free if you take the hub.
SocoNina
7
As it seems, 1000W on front suspension is not recommended. I see that you have other things though.
