Front crank for a whoosh big bear.
Garrydog
28
Manchester
Just baught used whoosh big bear , I want to increase the size of the front crank on the bike to keep in contact with the gears to stop spinning out.
Has anyone done this ?can anyone recommend a suitable crank ? I was thinking of increasing to 48teeth will this be ok. Also been looking at a sturmey archer single crank on eBay ,will this be ok with a Shimano set-up as on the bike?
Thanks.
8,529
Measure the BCD and bolt on a replacement, you may have to put in an extra chain link to lengthen chain.
For correct chain length remove chain form derailleur and put in on front & rear largest gear/chain ring and the ends should meet with a one link overlap.
16,857
Benjahmin
2,590
1,746
70
West Wales
I did it on the wifes bike.
Think we went 46, fitted new crank and arms. You will need a new chainguard though. Chain length was fine.
Here's my thresd, but it's mostly about cassettes.
I think just about any square taper set should fit.
