Hi, recently fitted the BBS01 250 W motor to my Surly LHT. Is there any options to change the front chain ring size down to a 36 ? Would like to try that first before changing the cassette if possible.
Cheers
Cheers
yep. They are UK distributor for lekkie bling rings and other stuff. I have one from them. Darren is very helpful guy over thereBBS01/02 Bling Ring | EM3ev
em3ev.com
You can find it in the UK if you search hard enough - maybe Brighton Ebikes.
I’m at work at the moment I have my old shimano deore Crank set although it’s x3 I will attach a picture later I would’ve interested to know if I could utilise it in any way. Thanks for the info.If you play around and have spare crank sets/ std chain rings you can add a double up front 36t being the smallest, though you need a spider adapter.
