Hello there,
I have so many things I need to separate from, please look at my ebay list of items sold and pick what you need:
cwah94 | eBay
Brompton trailer
brompton / folding bike universal trailer | eBay
6pcs/lot Titan B3 2-3 Cell 7.4v 11.1v RC Battery Balance Charger
6pcs/lot Titan B3 2-3 Cell 7.4v 11.1v RC Battery Balance Charger | eBay
20R Internal Battery Impedance Resistance Tester Meter
20R Internal Battery Impedance Resistance Tester Meter | eBay
Mini DC Red LED Voltmeters 15V to 120V Voltage Meter
Mini DC Red LED Voltmeters 15V to 120V Voltage Meter for Car Motorcycle 24V 36V | eBay
Turnigy Mega Checker 4-in-1 Battery Checker/Monitor
Turnigy Mega Checker 4-in-1 Battery Checker/Monitor | eBay
JST-XH 3S Wire Extension 20cm (10pcs/bag)
JST-XH 3S Wire Extension 20cm (10pcs/bag) | eBay
Ebike 400W charger 72V controller and voltage adapter
Ebike 400W charger 72V controller and voltage adapter | eBay
Ebike light and horn switch
Ebike light and horn switch | eBay
Ebike brake with switch off wires
Ebike brake with switch off wires | eBay
16T single wheel freewheel
Dicta single speed freewheel 16T | eBay
ebike pedal sensor
Ebike pedal sensor | eBay
Clark 650mm clamp
Clarke 650mm clamp | eBay
Set of wood, plastic hips and board sheet
Set of wood, plastic hips and board sheet | eBay
5 × 1mm Transparent hips high impact plastic sheet
5 × 1mm Transparent hips high impact plastic sheet | eBay
8 × 1,5mm hips high impact plastic sheet
8 × 1,5mm hips high impact plastic sheet | eBay
6 × 2mm black hips high impact plastic sheet
6 × 2mm black hips high impact plastic sheet | eBay
10 x 8mm new polycarbonate lexan sheet
10 x 8mm new polycarbonate lexan sheet | eBay
Blue storm pro 500w power supply
Blue storm pro 500w power supply | eBay
500w atx power supply quiet
500w atx power supply quiet | eBay
a pair of 9 pin waterproof male/female connector cable for motor
a pair of 9 pin waterproof male/female connector cable for motor | eBay
roll of 90m 24AWG 5 wires PVC cable for ebike
a roll of 90m 24AWG 5 wires PVC cable for ebike | eBay
Schwalbe kojak 32-349 16x 1/4 for brompton
Schwalbe kojak 32-349 16x 1/4 for brompton | eBay
I'm sure you'll find something in this list that will please you.
See the full list with pictures here:
cwah94 | eBay
cwah94 | eBay
Brompton trailer
ebike pedal sensor
Clark 650mm clamp
cwah94 | eBay
