HI, I'm Trevor from Mid Sussex. I ride a Freego Folder, early model with full throttle.
Lost all power apart from a bit of low power "stutter"
Checked all connections to no avail so I invested in a tester.
Everything seems OK apart from the motor hall sensor test which showed no activity on the blue wire.
Re connected everything, powered up and meter probed the connector
Yellow and green phase show 5v switching to 0v when wheel rotated but blue stays at 5v.
Now this is where I'd appreciate some advice.
I'm going to have to access the sensor to check the wiring and replace the sensor if necessary.
To access the cover I need to remove the gear cassette so I assume I'll need special tools for this.
Also the wires feed through that side, so is there anything I need to be wary of?
Trevor
Trevor
