I looked under one of my battery packs and where I’d soldered the BMS wires to the nickel strip welded to the batteries, there is brown-ish crud around the solder joint. Looking this up I discovered that the flux I use (standard ScrewFix stuff) might not be the best! Indeed, add a little water to this toxic flux and it might be as bad as pouring sulphuric acid on the nickel. The nickel is 100% or a midge’s dick near to it. However, I do get beautifully clean and sort of professional solder joints with this stuff and I’m not a good solderer.
Can somebody please recommend a good, non corrosive, good to use, solder?
