Hi, I want to fit a BBS01 to my giant escape. However I am concerned about the clearance between the motor and crank housing.
The cables for the gears run under the crank housing through a plastic fitting which adds about 8mm to the crank housing (See photo).
Will the clearance of this bracket and the screw (into the housing) holding it in place be a problem?
Thanks, Tom
Thanks, Tom
