That I haven't got Neil, like you I'm unable to get any technical details from Panasonic. Since the circuit board inside is encapsulated and the printed side buried, what all the individual connections are is concealed..
Normally that isn't a problem since both the controller and motor unit usually come with integral wiring looms having connectors that cannot be swapped, only one position for each. Here's the 250 watt motor unit loom for example:
The connections on the right are inside the motor unit, the ones at top left are the ones used to connect the controller and lighting if fitted, the one at bottom left is the battery connector platform.
I've never seen one with loose wires, so wonder what plug it is that you need to wire?
.[/QUOTe}
The display had no plug attached on the end with 8 coloured wires. I emailed the supplier pro-cycling-golla and they sent me two photos of a wired connect to set up the plug correctly.
I found a manual for Panasonic speed bike in the download section which has all the instructions on how to set up the display.
