I was prompted by the recent update on the post about stretching the rear droupouts to ask a question.
I have Bafang 250W rear hub motor with 7 speed freewheel fitted to a titanium mountain bike frame.
I have been trying out the current 7 speed gears with a real cheap (£10) pair of twist shifters which I find a fair bit easier to use than the standard triggers due to joint pain in my thumbs. The cheap shifters were just a trial and for long time use a better pair are needed.
At this point I am considering the possibility of changing the current 7 speed freewheel to a 9 speed one, Sunrace do a 11-32. Shifting (?) to a 9 speed setup would also allow me to use if needed the original rear (non-motor) wheel sets which are fitted with 9 speed cassettes. SRAM do Shimano compatible 3\9 speed twist shifters.
However the room in the dropouts would need to increase by around 5mm to accomadate a 9 speed freewheel and spacers will be needed on the axle. The droputs will spring apart by 5mm.
So does this sound possible, i.e. fitting a 9 speed Sunrace freewheel in place of the current 7 speed ?
