Help! First timer needing advice to buy an hybrid bike - Budget 1,750 to 2,500 Pounds
Glenn58
9
I am 61 years old and about to enter into semi-retirement. I am a big lad , some 145kgs and not in the greatest of health and need the assistance the ebike gives me rather then a normal bike. I recently purchased a motor home to travel around the UK and Europe in.
I need an alternative transport when I am touring as I don't want to obviously take the motor home down to get a pint of milk etc. I am planning to use the bike for general short trips - 1 to 10 miles, once I have parked up when toruing .
I also need the bike for general local travel as my wife uses our only car for work and for when I work for a few months of the year , here in Liverpool.
I have been researching e-bikes and as the article on this website, I have now gone mad with the research.
I have tested 2 bikes on the weekend as follows:
Raleigh Motus Lowstep Pounds 1,800
Trek Verve 2 Lowstep Pounds 2,450
The Raleigh was the first time I had ridden an electric bike and really enjoyed it and then I tried the Trek and fell in love with it.
I actually enjoy the lowstep as with my weight , it makes getting on and off so easy. I tried the bikes at evans bike show at trafford Quay in Manchester and road around the massive car park there where I easily got the bike over the 25klm speed as well as breaking sharply when idiot drivers were coming in and out of their parking bays.
The staff at Evans cycles were excellent , especially a guy called Tony who was really good.
I will be using the bike, virtually every day when I am touring and m most days when I am not to do local travels.
Most if not all of my riding will be on road with maybe the odd ride on gravel or laneways when touring so a hybrid bike seems to be the correct selection rather than a road or mountain bike.
I realise it is a lot of money but I can afford it , the 2,450 really is the limit though, if not a little above it. I want a bike I enjoy riding, needs to be super reliable, and can handle the odd hill to assist me when I am touring.
Given the money I am prepared to spend and this is my first time with little or no real knowledge, I thought it wise to ask people what they think and perhaps other suggestions.
Am likely to order the Trek this week OR investigate another bike depending on the advice here.
Thank you
2,750
Worth looking at Cube: probably come out between the Raleigh and Trek in price depending on model and deals.
For example: https://www.rutlandcycling.com/bikes/electric-bikes/cube-touring-hybrid-pro-500-2020-lowstep-electric-hybrid-bike-black_475956 . But they have lots of models and retailers; try a google search for 'cube lowstep electric' or similar.
Given your weight you can get https://wooshbikes.co.uk/?bigbear-ls for much less and it may just happen to suit you: but unless you are near Southend it may be difficult to try it out.
Glenn58
9
thanks for the advice - will look into them
have seen the cube before in shops and seem pretty good
8,529
Look at the Wisper Wayfarer step thru.
RobF
4,732
2,312
All ebikes are heavy, unwieldy lumps.
Do you think you can realistically lift one in and out of the motorhome on a regular basis?
A bike with a compact frame and 20" wheels would assist that endeavour.
Avoid the cheap, Chinese folders - they won't last five minutes.
There is a small number of good quality compact frame ebikes.
A Tern Vektron is such a bike.
It has 20" wheels and the same Bosch motor as the Motus you tried.
Much easier to handle, and it folds which might help with motorhome storage.
Given you are a big lad, the rigid frame version might be a safer choice.
The Orbea Katu is another rigid option, although you will probably want to remove the front basket to make the bike more wieldy.
The Motus Kompact is similar, but is folding only.
I have a similar design bike from AVE - now defunct.
It is surprisingly capable, I've done a couple of 80-odd mile rides on mine using a spare battery.
Almost as easy to mount as a step through, and thanks to the smaller wheels, very nippy.
More fun than a big wheel bike in many ways.
It is a niche product, so you might struggle to find one to test.
My local bike shop in Durham had a Vektron last time I was in, but I doubt that helps you very much unless you are prepared to make an outing of it.
Kwozzymodo
177
40
63
Lincolnshire
Have you thought about retrofitting a motor to a bike? You could probably put together a great ride for around £800, with a bike, motor and battery.
16,853
if you are looking into folding bikes, take a look also at the Woosh Rambletta, it is lighter and more comfortable than most folding bikes because it has a monoshock instead of the traditional suspension forks with two legs.
It is also solidly built. Folded dimensions: 83cm x 80cm x 43cm.
Unfolded: 175cm long.
The Rambletta has 36V 12AH battery, good for about 30-35 miles on a full charge.
We also have the Woosh Rambla with Bafang MaxDrive:
The Rambla has 36V 14AH battery, good for about 40-50 miles on a full charge.
Both bikes are suitable for taller riders.
Glenn58
9
I had given up on the folding bikes as I thought it would not handle my weight but there is a store picton cylces near me so I will give them a call and perhaps go down and have a look - with the motorhome having a folding bike has significant storage advantages - thank you
Glenn58
9
I am an accountant and unfortunately I have no mechanical knowledge at all so this is probably not an option but thank you for the idea
8,529
The Woosh Rambla is a very good alternative option to the Wayfarer, so on your travels in your campa van might well be worth dropping into Woosh HQ in Southend if ever down that way.
One thing you will get from both of them is really great CS and after sales service.
Glenn58
9
how can you organise a test drive - I am in Liverpool ?
16,853
We usually contact a customer near you who owns the model you are interested in for this purpose. Most are happy to help.
As this is a new model, this time would be with difficulty.
Glenn58
9
thanks everyone for your assistance and advice - ended up buying a scott sub sport e10 20 - was able to test drive and loved it
in terms of the storage in the motorhome I checked out the bike racks already installed and they are fine as well as the back of the motorhome as a configuration where I can store the bike inside the motorhome with a ramp my son is building for me after the stoage comments he saw here - Again thank you
