first time ridding for real
Markxc40
47
11
Hello all.
I'm about to collect my new e-bike nxt week. Apart from a couple of tours around the shop I not ridden any e-bike for any length of time. Is there anything I should do from a safety or enjoyment point of view before I set off.
Cheers
2,857
As with any bike, double-check the brakes are working, and the headset and pedals not lose. Keep the power setting low till you get used to it (may only be a few hundred yards) and increase slowly. I'm pretty sure the enjoyment will be almost instantaneous ... I hope so, and continue to enjoy.
Reactions: Markxc40
D C
1,145
578
Maybe keep the seat a little on the low side until you get confident but best to set it at the correct height as soon as you feel you can.
Don't use the highest power until you get used to it.
Don't worry, don't panic, you'll love it:)
Dave.
Reactions: Markxc40
MarcusT
83
39
NE Italy
Not knowing the terrain you plan on riding, be careful of over powering on steep uphills. It's easy for the bike to get away from you.
Reactions: Markxc40
Ocsid
458
272
82
Hampshire
Is that just an issue with cadence only sensing or a full power throttle, as I only have user as opposed to demonstrator experience of torque sensing, and simply can't understand that "warning" in the context of modern controls?
Back on subject, I would take a universal tool to reset things like the saddle height and its and the bars attitude, a spare inner tube, plus a strong lock to secure it if something gives way such that you need to walk, taxi or bus back to get the car for its recovery!
Reactions: Markxc40
MarcusT
83
39
NE Italy
Sensor with mid drive. It's happened to me while on rocky paths or hairpin turns.
Nev
1,507
2,520
North Wales
Same thing has happened to me but usually when I am in turbo mode. In these types of tricky situations I tend to use e-mtb mode and find I have much better control of the bike.
BazP
366
175
75
Sheffield
Ditto. It's very easy to lift the front wheel going over large rocks whilst in turbo.
Reactions: Nev
Related Articles
