first ride on yose/elife 350w rear hub kit fitted to kudos vita uno
footpump
713
75
76
first ride on kudos vita uno with elifeshop 350w rear hub.
set throttle to p4=1 so I have to peddle to engage thumb throttle speed set to 25kph
old freewheel shimano megarange 14-34 7 speed , new 14-28 (I normally would use 32f 14 rear on old set up)
tried a few different pas levels all ok but began peddling air on a slight downhill slope in 32-14 not sure if that's due to the moter being 350w and wound for more rpm .
throttle seems to be a bit quicker to get to 15mph than my 250w tdz2 subway.
got caught out on a hill ,where I had to stop to allow a van to pass, trying to peddle to engage throttle.
was going to try a higher speed /throttle setting while out, but could not recall the exact method of accessing settings.
not sure if upping the speed setting affects both throttle and pas or throttle only.
off to local bike hub tomorrow to get a new chain fitted and tweek gear adjustments.DSCF1608.JPG
