Like the title says, I bought a rear wheel e-bike conversion kit, installed it. I amusing my own home build LiOn battery pack from recycled 18650s. The battery is not the problem, it has plenty of capacity (14s5p). This kit has PAS level 1 thru 5. 1 thru 4 work well, when I select level 5 it stops working and then I lost all power and the LCD goes dead. All I have to do is remove power, unplug from the controller leads that go to the battery, then reconnect and I have power again. If I try to use the throttle, same thing it starts to move and then it dies, remove power, resets something I guess, reconnect power and LCD comes back on again. If I stick to PAS 1-4 no problem, works great.
I am wondering if when it tries to draw a certain amount of power it cuts out because the battery or the wiring cannot provide the level of current it needs. That is my guess. The wire I used for my battery to the controller is size 12, the controller leads that use maybe, kind of small I think.
Has anyone experienced this type of behavior? Any thoughts on troubleshooting steps or solutions?
Thanks,
John
Thanks,
John
