I've just returned from my first test run with my upgraded setup on my DIY Giant Trance.
I bought one of Dave's rear MXUS motor's with the cassette spline last year, and originally ran it with my 36v battery.
I've now rewired it with a BMS S12S sinewave controller and 48v lithium ion battery in a detachable bottle fitting carrier.
Unfortunately, there wasn't enough room in the Trance's full suspension frame, so I mounted the battery and controller on a backing board and fixed that inside a small 12 litre pannier bag.
The result is very stealthy, yet still reasonably secure, since the battery is locked into the carrier which is bolted through the pannier to the rack, (and out of sight). It's quite light, so doesn't throw the balance, and the weight is low well.
The range seems very good, 18 miles at an average of about 15 mph, and the GT battery meter shows only 5.5 amp/hours used up (half of the 10.5). The remaining voltage was just under 48 volts, so I'm assuming the BMS battery level gauge is fairly accurate, showing half the level left ?
