Finally a good sinewave controller for MAC motors
1boris
344
58
Dont know if this work with old version mac/ezee,read somewhere there was an odd timing or something with the hall sensors on the older ones.But it works exellent with my new Mac 10 cst motor.Just match the wires hall wires and motor sensors color for color.It is VERY quiet .And you can use modern lcd displays with it.Not only a 3 speed switch and a throttle like before.That was the big reason I wouldnt use a Mac before
https://bmsbattery.com/ebike-kit/721-s12sn-1000w-40a-torque-simulation-sine-wave-controller-ebike-kit.html
1boris
344
58
For information this is the ONLY controller that works with the MAC motor on BMS Battery site I was told.So the s12s or others will not work
antenorareal
10
PT
Does it need speed sensor or get the reading directly from the motor?
Enviado do meu SM-G850F através de Tapatalk
1boris
344
58
It get info from the motor,but the speed is much to high on mine.Maybe just the lcd parameters
antenorareal
10
PT
Now is it ok?
Is good to know that is a alternative for the Mac infinion CA...this way is mutch more cheap to have a mac motor
Thanks for sharing :)
