I am looking to exchange the stock controller with the S866 + Brain Power 36v controller and I am having difficulties. There are some old threads on this controller, but I can't seem to find solution there.
The problem is:
I have connected power and all motor connectors and performed the self learning - which seemed to work. However the display shows E07 at all times (apparently motor failure error).
I set walk assist on and this functions as expected. I then connected the throttle (nothing else), but this gives no motor movement at all.
I have not connected PAS sensor yet, as the stock sensor does not work with this controller.
I have reconnected the stock controller and it works perfectly.
I have settings as shown below.
The controller is as in the picture below, but with model no 866C-6 on the label.
Any advise is appreciated.
P01: (set at 2) Backlight brightness level: 1-3 (3 = maximum brightness)
P02: (set at 0) Metric / imperial units: 0 = km, 1 = mile
P03: (set at 36)Voltage level: 24V, 36V, 48V, 60V, 64V (Default = 36V)
P04: (set at 10) Sleep time in minutes: 0-60 (0 = disabled)
P05: (set at 1) Number of power assist levels: 0 = 3 level mode, 1 = 5 level mode
P06: (set at 16) Wheel diameter in inches; accuracy: 0.1; This parameter is needed to display the
speed accurately
P07: (set at 80) Number of speed signal magnets inside the motor × motor reduction gear ratio:
1-100; (set at 100) This parameter is needed to align the actual bicycle speed with the max speed
setting.
For a regular hub motor, enter the number of speed signal magnets inside the motor;
For a geared hub motor, multiply the number of speed signal magnets by the gear
ratio; number of magnets × gear ratio = input value;
Example: number of motor magnets = 20, (reduction) gear ratio = 4.3
Input value = 20×4.3 = 86
P08: (set at 25) Speed limit: 0-100 km/h, 100 means unlimited speed. The value indicates the
maximum speed of the bicycle.
P09: (set at 0) Zero start: 0 = zero start, 1 = non-zero start
P10: (set at 2) Drive mode:
0 = PAS (1:1) enabled (throttle is disabled)
1 = Throttle enabled (PAS is disabled)
2 = PAS and throttle are both enabled
P11: (set at 1) Boost sensitivity: 1-24
P12: (set at 1) Boost start strength: 0-5
P13: (set at 12) PAS type setting: 5, 8, 12 magnets
P14: (set at 12) Controller current limit value: 1-20A (Default = 12A)
P15: (set at 29) Controller undervoltage value:
P16: ODO reset. Press and hold the plus button for 5 seconds to reset
P17: (set at 0) 0 = Walk assist enabled, 1 = Cruise control enabled
P18: (set at 100) Displayed speed adjustment: 50%~150%
P19:(set at 0) 0 gear: 0 = disabled, 1 = enabled
P20: (set at 0) Communication protocol: 1 = Protocol 2, 2 = Protocol 5S, 3 = Alternate protocol.
Do not change, leave set to the default value or your S866 display will not be able to
communicate with the controller!
P21: (set at 0)
The problem is:
speed accurately
setting.
P21: (set at 0)
