Total newbie to ebikes, but experienced mountain biker.
The bike is a Felt Lebowsk e fat bike, hardtail, see the image.
I have taken the stock Rockshox Bluto off and fitted a Lauf fork in its place. Other upgrade was to the DT Swiss wheels and made the tyres tubeless.
It has a Bosch 400 w battery as standard.
Tyre pressures at 8 psi front and rear!
My first ride was my usual Afan Argoed off road trails mix up.
Rode up The Wall and then over to Whites Level descent.
Ride in total was 30 miles with approx 900 metres of climbing.
Had two bars on the battery when I finished the ride, which slightly (pleasantly) surprised me.
I used Eco for about 80 - 85% of the ride, and only used Tour when the climb got a bit steeper.
There is a little gyroscopic effect going on with the front wheel which is normal for fat bikes, and steering can have a mind of its own sometimes.
The ride using the battery is really good, eco supplies that extra support for nearly all riding, and makes climbing singletrack fun again.
The spec on the bike is top notch really, although I realise the Lauf fork is a little marmite.
The fork is very light weight,soaks up the general ( normal) trail chatter really well. Climbing with the fork is good, as you don't need much more travel than the 60 mm on offer.
No rebound control, so takes some getting used to.
Descending is fine, as long as you are not going like a downhiller.
