Faster charging with parallel chargers.
gkspud
18
43
scotland
Ended up with 2 chargers due to shipping times for one of em being too long and buying another elsewhere, after googling about it and not finding much or generally not advised i decided to ignore that and see what happens for myself, and surprisingly works just fine,
one
and 2 connected
using 2 cheap 2.5A chargers and it did 9.9ah charge in just under 3 hours, was near empty to full, 10.4ah pack
edit i am not responsible for escaping smoke, the kits to put it back in are getting scarce.
Alan Quay
2,351
1,076
Devon
one
and 2 connected
All you are doing is increasing the charge current.
The charging current limit is not there because of limitations in the charger. Its there because the battery can be damaged by charging too fast.
Sent from my HTC 10 using Tapatalk
gkspud
18
43
scotland
obviously pay attention to your battery specs, the cells in this one i have was charged in around an hour with the original charger.
You can damage batteries by charging too fast. With any battery, the faster you charge it, the shorter its life. Don't do it unless you have to.
gkspud
18
43
scotland
this charger is underpowered for this battery, 2 are aswell, original charger was 3.6A 145W for 1/4 of this pack, as its made from macallister garden tool batteries.
edit just looked up cell specs, standard charge is .5A and rapid charge is 4A, which is higher than i thought, as original charger worked out about 1.8A
