Hello I have Famex ride 2000w ebike kit and I’m hardly getting any speed I have sw900 display but this display has 21P settings compared to my other display which has 16 any ideas and how to set up
Is this one specific for my one which has 20 different settings
P08 Speed limit. Range: 0-50km/h, 50 means without limit
My controller has 40ah+05V would I set the ah to on display to 35?no idea on that display or what firmware it is using but max voltage wheel size max amps and no speed limit should get it going faster.
The battery has 50ah dischargetry 30 and try that first but can the batt handle that much?
Well it rated for 50ah continuous dischargetry 30 and try that first but can the batt handle that much?
Mine says on my display 100 but I’ll try 50
My 2000w motor is not doing 2000w doing 900wyou will nuke that batts range the faster you make it go mind
