eZeebike (iOmega) controller throwing an error code.
RschDev
9
My bike (eZeebike iOmega) has been working really well but lately there is an interesting issue. Every once-in-awhile, the motor just stops working. Nothing I do (peddling or activating the throttle) helps, but after a couple of minutes it starts working again. The cycleanalyst shows good voltage and the indicator shows the throttle is being activated, but the motor doesn't operate. Today I noticed something that is probably diagnostic. There is a red LED on the controller that is solidly on when the bike is powered on and working. When the problem occurs, the LED blinks on five times, pauses, blinks five times again, pauses, etc. When the problem goes away, the light is solid again. Does anyone have a clue what the five blinks indicates?
MontyPAS
390
148
5 blinks = Throttle failure
RschDev
9
THANK YOU!!! That was exactly what I was looking for. Cheers!
RschDev
9
Investigated the throttle and found a suspect connection. I patched it for now and it's working. I'll replace the connector tomorrow. Thanks again for the pointer.
Reactions: MontyPAS
3,990
Throttle error is given when the controller receives a non-zero signal when you switch on the controller. It's not something that could normally happen when riding. Logically, the controller is restarting for whatever reason while you hold the throttle open. See if you get that when you leave the throttle permanently closed.
RschDev
9
A day later and the problem has returned. I have replaced the throttle connection and the connection is solid (tested with a meter). The problem remains. While the Cycleanalyst shows plenty of voltage and indicates that the throttle is working, and that the brake cutoff switches are not activated, it just stops powering the hub motor. The pesky 5 flashes happen. I am confounded but am wondering if the issue may be in the wire that goes to the controller from the battery. I hate intermittent problems.
RschDev
9
I get the same error when running the motor via the pedelec and not activating the throttle.
3,990
Did you try connecting the throttle direct to the controller? Why are you running it through the Cycle Anayst? With the Cycle analyst, it's dead easy to make an incorrect throttle signal via your programming especially if you're running the PAS through the CA and converting it to a throttle signal.
Reactions: MontyPAS
TopEParts
China
Here's the exactly same led display, in case of you need it for replacement.
