Ezee Sprint Test
The Lead acid charger managed to charge the battery two full last night, I took the case apart so I could keep an eye on the temp of the batteries well they were being charged the temperature sensor was just hanging lose inside the case so I used a glue stick to attach it to one of the middle batteries, I let the charge go two 42.5Volts at which point the batteries started to get warm so turned the charger off, checked the Voltage this morning before going out the voltage had dropped to 41.6Volts.
The first 9 miles were though Norwich city a fare few starts and stops then went on to marriotts way
Norfolk Countryside which is an old N gauge railway track very flat, After all the rain we have had is the last 24 hours it was quit muddy with a lot of puddles,the bike got very muddy and wet but no problems with the electrics which these early model are known to have, although I still intend two waterproof the bike when I get a chance. The battery meter on the handle bars didn’t seem to be very accurate so decided to turned it off as it was misleading,The battery Started to drop off power at a distance of 22 miles dead at 23 miles, tested the voltage when I got home 34.7Volts = 1.15Volts per cell,. I think a run on tarmac the battery will last a little longer, I will leave the recelling a little why’ll, a few full changes and discharges mite also improve the battery’s performance, as I don’t know when it was last balances if ever. Time will tell. I have ridden a few Electric bikes now this is a very easy bike to ride without power, not as light as my Giant Lafree but a little more comfortable with the front suspension and the big sprung seat, its a good hill climber and will cruse at 16 mph no problem and will go up to 18 mph when needed, the motor is quiet and smooth with plenty of toque all in all a very nice ride
