Ezee motor question
wehey
120
54
Hiya all
i have an Ezee motor approx 2 years old.
when I got it I had to wire in an L10 connector to make it compatible with my Baserunner controller.
during the process I noticed an extra thin white wire, along with the usual hall and phase wire.
I contacted the vendor to find out what it was for but he never replied, so I left it disconnected.
Would anyone know what this wire does?
The reason for asking is because I’ve just added a Cycle Analyst and I’m having strange speedo readings and am wondering if the white wire is meant to be the speed sensor?
thanks
8,842
Your thoughts are correct it is for a Speed sensor if the hub has a Hall and magnet installed to read it.
Reactions: wehey
thelarkbox
1,675
520
oxon
Test the signal wire for a pulse with the wheel spun backward to confirm its a speed sensor, otherwise its possibly a temp sensor signal.
Reactions: wehey
wehey
120
54
I have managed to get an email to Justin at Grin. if anyone knows it will be him.
im waiting for his reply.
8,842
A simple meter test will tell if the wire is switching 5v by slowly rotating the wheel C/W, very few/rare for a hub to have a temp sensor as well as mid drive how many do you know that have a temp sensor.
Typically all hubs that have six Hall wires , the white one is for speed sensing.
My TSDZ2 has a temp sensor but only because I added one.
matthewslack
2,594
1,671
Speed sensor and thermister for temperature.
wehey
120
54
I didn’t get a reply back and so just decided to connect the white wire back into the loom…….and hey presto, it all works perfectly now
