As promised I've added a couple of pictures of my 48v conversion on an eZee Liv.
It's the earlier model with Brushed motor. It came to me from a friend who was scrapping it. The battery had been retained by the dealer who had condemned it, the owner retained the charger (he has 2 other eZees) and I paid £25 for the bike.
It's very tidy but was well overdue a service. Its had that, including the motor stripped to clean/derust/lube the freewheel mechanism.
I ran it up and down the street using a standard battery off my wife's Torq and it behaved just how these Livs do - sluggishly.
I have someone who is keen to buy it if I can pep up the performance. Given that, I decided to do a 48v conversion on the bike - given I needed a new battery and charger anyway.
I purchased the vertical, drop in battery from BMS. 48volt, 10ah and supplied with fitting equipment.
The fitting should be straightforward and it is to a degree. You do need at least basic workshop facilities and a workstand though.
I'll post some pics and come back later - I do have issues I'd like to discuss!
This is the battery:
This is the modified connecter. The pins are in a different orientation to the eZee ones:
This is the battery and new brushed controller as fitted:
I'll post a bit more about it later
