EZ Rider Kit - popped one open to see what's inside (Brompton conversion)
mickkerr
Jan 28, 2024
Hi all.
I'd previously had a commuter DIY project that did me well for many years.
It was a Giant hybrid with a mid drive BBSHD.
Loved the thing to bits and managed to get it to behave exactly as I liked
- PAS settings would go from non existent, to slight increments of power
- felt like you could ramp up the PAS levels to go from the spectrum of emphysema to lance armstrong
- PAS9 was effectively a motor bike (rarely bothered with a throttle, and just ghost wheeled)
Recently bought myself a second hand Brompton and love the thing to bits.
Have a potential 10-15km commute coming up, and figured i'd fiddle with a front hub conversion.
Got one of the EZ Rider kits available online.
Installation was very simple and straightforward.
The ride is rather disappointing, to the point that I'd rather not use it, and have since removed it.
I think it's mostly to do with the programming from the controller. I'm wondering if I can salvage the kit and make it better. Couldn't see this anywhere else online, so figured i'd do it. I've popped it open and will attach piccies of the bits.
I'm likely going to misuse terms, my apologies.
I think my issue is that the controller is modifying the max assist speed with the PAS levels. Default was set to PAS1-3, can change the settings to 1-5 or 1-9
- so PAS 1 will kick in with too much power, to say 15kph, and then die
- PAS 2 will do the same, but to a slightly faster speed
- PAS 3 be ridiculous motorbike mode (as much as 250w can be)
what it means is that with a 3 gear brommie
PAS1
- taking off is fine, it ramps up as cadence increases
- hit around 15kph as switching from 1st to 2nd
- speed limit on PAS1 seems to be hit, and no further power output at all
- rather annoying, pretty much only useful going up a hill
- no power at higher speeds means i can feel the drag and increased weight, for no real benefit
PAS2
- power ramps up too quickly in 1st gear
- second gear is also a bit too powerful
- switching 2nd to 3rd and it totally dies in the arse
- cadence drops with the gear change, and there's no power
PAS3
- it's effectively a motorbike
- not ideal as I want some battery efficiency
What i'm used to is this:
where i could program the BBSHD PAS levels to cut out at 100% of max speed
so for example:
- if max speed = 30kph
- PAS 1 = 33% max current and 100% max speed
- pas 2 = 66% max current and 100% max speed
- pas 3 = 100% max current and 100% max speed
rather than
- pas 1 = 33% current and 33% max speed (ie 10kph cut off)
or what it feels like it is:
- pas1 = 70% current and 33% max speed
I've gone through the settings and can't seem to make any difference
I'm guessing that this is simply a limitation of the hardware, and i'll need to change the controller.
On that note - I couldn't find any info out there on what was inside.
So here's the guts.
Controller:
Looks like an M15 (has m15 printed on the back of the unit)
Similar to here:
manual attached
Though might be a different version with more limited functionality
- I wasn't able to get into some of the menu options they show
I'm guessing that I'd need to change both the controller and display to get the sort of experience that i'm after?
cheers!
harrys
363
101
73
Chicago, USA
The EZ-rider kit appears to use speed control. I've found that operation mode to be quite irritating. The power should max out when you hit a certain speed and that allows the rider to blend in human power to go faster. I like current control.
I would swap it and the display for a 14A to 20A KT sine wave controller and a KT display that can modify the current. With many of them you can cut by 50%. That allows you to buy a higher current controller unit for future use on a bigger bike. With 20" and smaller wheels though, I think 17A would be fine.
StuartsProjects
1,798
1,014
Maybe.
I have a DIY eBompton conversion using a KT controller.
Its a pleasure to ride.
Its got 3 speed rear gear, not sturmey archer, but the controller copes so well that its rare that I use the gears at all.
mickkerr
Jan 28, 2024
yeah, i figure having something that's not speed controlled would be great.
i'm really really impressed with the hub motor (having only ever used them before on lime bikes / similar)
suspect what i'll end up doing is keeping the motor
getting a KT controller and small display
i'll probably jam everything into the case i've got, so that i can mount it on the front carrier block
Peter.Bridge
1,328
609
Topbikekit on AliExpress has a range of folding bikes front wheel hubs with 74mm between dropouts and various wheel sizes / rim sizes, these have KT displays and controllers, that you can also buy separately. eg https://vi.aliexpress.com/item/1005002919596473.html?
