When your bike doesn't work, you should never start buying random parts on a hunch. Get a meter and start testing. If that switch is faulty, it would take less than a minute to confirm, and it's very simple to override it .My Evora folding bike has just stopped working. It does not power up. Am advised the battery is good and it maybe a fault with the on off switch. Does anybody know where i can get this new switch from pleaseView attachment 57831
Thank you for your helpful reply i attach to photos The first one is from the switch the second is on the end of the loom wiringWhen your bike doesn't work, you should never start buying random parts on a hunch. Get a meter and start testing. If that switch is faulty, it would take less than a minute to confirm, and it's very simple to override it .
The first thing you need to do is unplug the connector to that device and show us a photo.
Moulded connectors make it much more difficult. Here's how those things work:Thank you for your helpful reply i attach to photos The first one is from the switch the second is on the end of the loom wiring
Throttle has three wires: ground, 5v and throttle signal (1 -4v).
The battery display has one wire : battery voltage.
The switch has two wires: in and out.
The problem is to identify how exactly it's wired. Ideally, you'd have to open the controller to see which wire goes where, but you can probably test the switch directly on the connector, but you'd have to go through all possible combinations. Two of the pins would have continuity with the switch in one position, but not in the other position.
The throttle is a Wuxing 62DX. They turn up on Aliexpress, Ebay, Amazon and at Chinese resellers, but the chance of getting the same connector wouldn't be high.
Perhaps dont give up?Thank you Saneagle for your advise.
I have done a search for the replacement part Wuxing 62Dx but they all seem to come up with 3 pins not 5. As for checking the wires i think its out of my skill set and plus i do not have a meter. Maybe i will sell it as it is for someone who has the know how to repair it.
Thank you for your advice but have not be able to locate such switchMoulded connectors make it much more difficult. Here's how those things work:
