Error code 8
Van Nieuwerburg JP
20
65
ghent
Suddenly the Bafang BBS02 motor stops running
I get a error 08H controller report on the screen (motor hall signal wire error)
I open the controller and made a connection to a other motor and it worked
So the controller is it not
Then I connect the controller to the faulty motor
I do not connect the black connector and the error code do not appears on the screen
So I think the pas circuit is defect or is it the hall sensor?
I have cut the white wire from this connector, for only throttle use
I only find a pas circuit by greenbikekit
califonia e-bike write:
We have tested many motors and never found a faulty hall sensor. If this happens to you, try unplugging the Pedal Sensor (PAS). The black connector inside the controller housing. We are finding that when you do this the 08H problems goes away. If that is the case for you, just replace the PAS circuit. We suspect that some of these circuits are pulling down the 5v power circuit in the controller triggering the hall sensor error 08H.
This motor is brand new and this happens, is this normal?
any comments or suggestions welcome
If you get any fault on the 5v rail, which includes things like water in the throttle or in any connector with 5v in it, you can get 08 error code. Basically, all sensors can be affected by a fault on any of them.
