Electrical help - fuse types, and wiring conventions for accessories
pn_day
185
40
St Andrews, Fife
Hi all,
Apologies for all the questions - I've been reading away both here and over at endless-sphere, but there are still some things I'm confused about.
I'm going to be building (when the bits arrive from BMSbattery) a 36V "nominal 250W (actually 500W)" CST ebike.
Adding fuses seems like a good idea.
I'm assuming inline 'blade' fuses like the automotive industry use are a good idea? Something like http://www.ebay.co.uk/itm/300640459432?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
Should I have one direct off the battery before it gets to the controller? If so, any idea what the inrush current is like for the S12S/S12P/S12SH are like? They are rated at 22/30/35 A respectively. I was thinking 40A fuse between battery and controller might be a good safety net?
Additionally how do folks usually wire in accessories like lights. Do you use a common ground through the frame, and just route +ve to all lights, or wire in + & - to all lights and tie the grounds together back to battery ground?
What are the thoughts on waterproofing handlebar switches and throttles? I've seen the discussions that suggest dielectric grease and a bag over the top, but was wondering if anyone else had any bright ideas?
Thanks,
Phil
pn_day
185
40
St Andrews, Fife
Thanks Andrew,
I have a cheap DC-DC converter on order from fleabay for one of my lights (8.4V Cree), but the others I've ordered run off 20-80V supply so should be OK.
Thanks for the links - that ebikes.ca USB one looks nice.
Phil
Alan Quay
2,351
1,076
Devon
I also have a CST, with a 30a controller.
Fuse - I have a blade one, 40A. Install as close to battery as practical, before the controller.
This is the one I bought:
http://www.ebay.co.uk/itm/SPLASH-PROOF-LINE-STANDARD-BLADE-FUSE-HOLDER-TRUCK-HOLD-CAR-BIKE-BOAT-BIKE-/380863802235?pt=UK_BOI_Electrical_Components_Supplies_ET&var=&hash=item97645d0a1c
Don't use the 'Mini Blade' fuses, as they melt - mine did anyway.
0v - I have never bothered with using the frame for 0v, although I expect it would work for all but Carbon Bikes. As you suggest, just bring all the 0v lines back and common with battery 0v.
Hope that helps
I prefer two wires for the lights. earthing the frame is not really necessary, and is a it more risky. That fuse-holder should be OK. The inrush current is very high, but for a very short time. I don't think it'll blow the fuse.You only need to connect once anyway because the S12S/P has a switch that can block the current down to microamps, or do you need to disconnect lipos for charging.
I'd use a 40 amp fuse if you run with 30 amps, which is about the max for a CST.
pn_day
185
40
St Andrews, Fife
Thanks chaps. Very helpful. Mike that fuse holder is better than the ones I've found - rated for 40A.
Unfortunately I am going to have to remove the battery for charging at work - thus the interest in fuses!
Thanks for the tips on lights as well - good to know what others who have successfully built CST based builds before have done.
On a somewhat related point, does anyone have a source for labels that state something along the lines of 250W nominal? Or does the CST have no visible power labels on it anyway?
Thanks again.
You need a photocopier or laser printer and a roll of sticky backed aluminium tape about 2" wide
  • Design your label
  • Print it on plain paper. place a piece of the aluminium tape with its backing still on over the print
  • Hold it in place with a couple of strips of normal selotape that just overlap the edges
  • Put it back in the printer/copier in its original way round
  • Print/copy again, and the new print should come on the aluminium
  • Cover the label in wide clear selotape or clear sticky backed film to make it weatherproof.
  • Cut out the label, peel the back off and stick it on
Here's one I've seen done like that. It's not on any of my bikes;)
Reactions: pdarnett and Arbol
