Could someone who has used one of these glue guns, tell me if the glue can be softened and removed, by reheating the set glue with a heat gun or hair dryer.
I'm replacing one of my hall sensors attached to a tiny pbc inside the motor.
The pbc and sensors are currently held in place with a resin that can be heated and removed quite easily.
I need to be able to fix the pcb back in place securely, but not so much that it cannot be removed again, in case of another hall sensor failure.
