electric bicycle weight
pocruadhlaoich
Aug 28, 2017
ireland
Hi,
I recently bought a Raleigh Motus and have been using and enjoying it greatly. At the weekend I cleaned it and had a complete nightmare trying to remove and replace the rear wheel for cleaning. Given the weight of the bicycle (20+ kg), are there any good techniques for wheel changes? Trying to hold such a weight up with one hand while pulling on the rear derailleur with the other hand and trying to somehow attach or detach the wheel was very difficult. Should I try to raise the bicycle up somehow? Is there such a thing as a portable bicycle stand for lifting the rear wheel for maintenance?
Thanks for any help!
Benjahmin
2,771
1,822
71
West Wales
I have a stand like LP linked to. Wheel removal can still be tricky, though easier. Can't use it with the wife's step through though, just can't find the balance point.
tommie
1,761
601
Co. Down, N. Ireland, U.K.
Reactions: LeighPing
TedG
466
494
75
Lisburn Co Antrim Northern Ireland UK
Bought a bike stand from Dirty Pro Tools via Amazon. For £28 it is astonishingly good value to support a heavy e-bike.
Solid rubber faced clamp in the right place for balance and widely spayed tripod legs make working on any part of our bikes so easy.
This is not a feeble wibbly wobbly affair, I can't work out why it is so cheap. Check out the 600+ positive reviews.
Recommended - and I am not easily impressed! Look it up.
MAJOR EDIT!!
It has four legs, not tripod. Sorry folk, senior moment.
TedG
466
494
75
pocruadhlaoich
Aug 28, 2017
ireland
Hi all, thanks for the replies so far! I will check out the maintenance bike stand idea, that sounds great. I guess I was thinking more about the scenario where you are out on the road, get a flat on the rear wheel and then need to lift and hold 20+ kg, pull the derailleur and somehow jiggle the wheel out and later put it back in again.
pgwyse, I was recommended to not place the bicycle upside down. Confusing :S
These would do your job just fine, Lidl were selling them recently and they`re always on Ebay
Also your fellow countryman Danidl has a Motus, maybe he could chime in
Nice of you to remember me.
Just remove the intuvia display and turn the bike upside down on grass.. that is the green stuff not the special tobacco. The brake handles are solid enough and the assist control is robust. The only part I would worry about is scratching the face of the display on gravel or concrete. . the wheels come off in a jiffy with those quick release thingies.
. Because the bike is heavy, I would put it on its side and then rotate. On a lighter bike, I would have just rotated it over the back wheel,. But that would damage the mudguards
You would want to be Houdini if you are trying to hold a bike in one hand and insert a rear wheel with the other, while using yet another hand to move the dereilliur back...
If removing the front wheel , make sure you disconnect the dynamo lead first and when replacing make sure you tighten the wheel before reconnecting the dynamo. .. if the wheel axle rotates it will damage the flimsy connector.
Tyres may need to be deflated to get past the brake pads. Incidentally I see that the newer model seems to have gone to disk brakes, rather than the rim brakes on my model.
I would strongly recommend replacing your two tubes with those slime filled tubes available from Halfords and elsewhere. Then you can at your leisure fit them at home and enjoy many miles of puncture free riding.
TedG
466
494
75
I was going to ask if it was a good idea to fill my current tubes with Slime to prevent punctures. Some say it should be used to repair a flat at the roadside and others say it should be installed to prevent possible punctures.
Anyone with any experience?
For 60+ years I have been a sticky patch person but if this is a new product to eliminate the hassle then I am all for it.
If the Slime works, fine. But when it doesn't and that can often happen, the resultant mess ousing out makes it impossible to effect a patch repair on the road. It hasn't worked for me when i've tried it more than once, so never again, patching's easy and reliable.
Reactions: TedG and danielrlee
I've never used slime. Since I've been using puncture resistant tyres, I've never had a puncture, so I've never felt the need for it. That's about 6000 miles.
Reactions: TedG
Best course on bikes. A year and a half on puncture resistant Kendas and no punctures, followed by all the years since with Marathon Plus and just one slow puncture. Don't know how many thousands of miles altogether across three e-bikes.
It was a different story on the trailer with 16" nondescript Chinese tyres though, punctures galore, and different brands of slime didn't help at all, just made matters worse.
Reactions: TedG
