Hello & 2 questions from British Columbia. I live in a semirural area but manage without a car with grocery bikes I make for myself by cutting diamond frames at the seat tube and inverting the front. Then reducing the front wheel to a 20” “farthing” and building a frame hoop above it to drop a cargo bucket into. econologica.org/p2017.html
It would be good to have electric assist eg if I have to get the 7 miles to a hospital A&E hurt or ill possibly at night. Over the years I have topped the chopper handlebar U into a closed loop which I can rock back and forth for extra muscle power in hills. But this makes it impossible to slip e-bike controls on. So Q1: I have to add an magnet to a brake lever and a sticky back sensor to split-able aluminum? brake housing? and put a thumb-throttle on a stub tube?
I have to lift the bike over a highway median, so can’t add much weight. I have been looking at a small assist motor preferably as a mid-drive. I already have a Shimano front-freewheeling FF chainwheel. I cannot find a 250w brushless with a built in reduction so I am thinking of using a (unspoked) Xiongda YTW-06. It is small enough to mount “GNG” style on the chain, but then would have to run backwards which Bonnie says isn’t possible, even if the roller clutch is put in backwards. Q2: Has any member opened up a YTW-06. ?
Simon Farthing
Simon Farthing
