Ecoride 2016 - change wheel size in the LCD
StefanL
Oct 25, 2016
Sweden
Hi,
I did notice that all 2016 ecoride (Ambassador, Summit, Urban8, Flexible, Explorer, Shortcut, Fatbike 20/26/28”) bikes have the same controller, LCD and I think identical motor.
So question is if it’s possible to configure/change something in the LCD (hidden menu) to make it go a little bit faster, like wheel size?
8,526
Good morning Stefan and welcome,
Trial and error sometimes playing with lcd menu's, before changing any info make sure you make note of the original settings. A simple wheel size change to a smaller wheel may fool the system and give a higher speed cut off however km data recording will be out. Sometimes on Chinese controllers they have a exterior speed limiter connected which is just a small cable link, unplugged this releases the speed limited and gives about 30% more.
The only thing I can suggest is to press and hold both the plus and minus buttons while you have the wheel size on the screen. If it starts to flash, use the minus button to reduce the size.
