Ebike lights for 85volt battery
Andy1865
290
15
Good evening All, could somebody recommend some reasonably priced lights and switch for a 85volt battery. How to wire it up and is it ok to splice onto the output cable of the battery as the cable is directly into the battery box meaning i have to cut into the cable to locate the correct colour of wire.
Thank you.
jimriley
596
399
I've just fitted one to a 36v battery with no issues, double connectors on the battery out leads, 3a microblade fuse. I suspect your problem will be sourcing a light , most I saw were only up to 60v.
Andy1865
290
15
I seen some lights 12v to 90v but unsure on wiring them up because of the cable situation that i mentioned in my first comment...to splice or not to splice.
Do all on/off switches come with a built-in fuse??
Andy1865
290
15
[/URL]
Whats your take on these ebike lights please?
8,533
The link doesn't work an invalid source.
There are ones (front) on ebay that work to 85v but whether the top limit has any leeway ?
What about a rear light ?
For fusing one needs to implement an inline one on the v+ line.
If the controller has no specific light out put, take the power directly off the battery feed to the controller (splicing) and place the fuse close to the controller on the v+ line. Wuxing make a handle bar on/off switch it may take 85v but it depends on the lights current input, if it is only about 1a then I would think you will be ok.
A safer option to 85vdc which is a high voltage level to use is some usb lights or similar lights using a separate battery source from 12 - 48v.
Andy1865
290
15
If the controller has no specific light out put, take the power directly off the battery feed to the controller (splicing) and place the fuse close to the controller on the v+ line. Wuxing make a handle bar on/off switch it may take 85v but it depends on the lights current input, if it is only about 1a then I would think you will be fine.
062C Motorcycle E-bike 12V-90V LED Headlight Headlamp Spot Light Waterproof Lamp
Andy1865
290
15
Andy1865
290
15
The first three photos are of the light and switch, then followed by a photo of the wires between the battery and the lcd, then ladt two are of the wires from the motor to the battery, or maybe i am just better leaving it alone and useing normal battery lights?
Hope maybe that helps.
Thanks.
3,993
Who built this bike? By the looks of your knowledge, it wasn't you. I'm really worried that you want to do this wiring and you haven't been able to identify the battery and its wires. It's normally pretty straight-forward.
Step 1. Find the battery
Step 2. See what wires are attached to it - should be thick black and red.
Step 3. take a photo and show us these wires and how they're attached to the battery and the controller.
Without buck converter:
39187
Using buck converter:
39188
Andy1865
290
15
Thank you very much for the diagrams vfr400. hi-power cycles.biz built it. The only thick wires are these
3,993
They're the motor phase wires that run from the controller to the motor. Follow them back to the controller, where you'll find the battery wires red and black.
Andy1865
290
15
The controller and batteries are inside a metal blackbox which i can't get into unfortunately.
3,993
Very similar to this photo
It's weird, I can never remember peoples faces, but i never forget an ebike. That's our old friend Banbury Frank, who deregistered from the forum when there was some discussion about quality and legal issues with his bikes. He's changed his trade name a couple of times. First it was Xipi, then something like Wind Bikes, now trading under Hi-Power Cycles. He was quite helpful on the forum, but reportedly not very good with his own customer service:
Why can't you get into the box? You must be able to, otherwise how did they get the battery and controller into it?
Andy1865
290
15
The screws are 8 pointed star shaped and ive not got the right driver for them. So basically a no go
3,993
Andy1865
290
15
Thanks for that vfr400
