DT Connectors
smokey
Jan 4, 2012
Hi all have just purchased a Tongsheng 250w motor along with a ZT-SH1/2 Battery 36v, this battery uses a screw on connector for its discharge lead, im just enquiring is it ok to use 2 pin DT Connectors for quick battery removal for charging, otherwise i will have to use bullet connectors and then remove lead from battery, this lead can be very tricky to remove if you have cold hands. Anyone used DT Connectors on batteries before.
