Dropper (Seat) Posts have pretty much past me by since their invention, I understood the concept for off MTB riding, slamming the saddle on tricky descents and technical stuff where you have to hang you arse out or get lower on the bike, but having now discovered them (one factory fitted on my most recent bike), I can not only appreciate the benefits off road, but I have found they are a game changer on road and busy traffic full commuting.
To be able to reduce the saddle height when approaching a junction or a slow down and stop so to comfortably get your feet down flat is brilliant. Then to pop the saddle back up at a flick of the handlebar switch when you pull away again so your legs are fully extended at the right height. Also, just reducing the saddle height slightly on speedy descents or say when the road surface might be a little slippery adds a level of confidence knowing you can get your full foot flat down in a skid if needed.
If you are doing a lot of commuting (or ride on trails/off road), and stop/start stuff, I think starting from about £50 for a cable operated handlebar lever one they are a great investment. You can get external cable ones or internal cable routed ones
