Fitting the kit was very straight forward. No hiccups what so ever.hi trolley thanks for the suggestions ,i like the look of the carrera ,and will google the others. how did you go on with fitting the kit,and what are your impressions so far thanks
Good to hear the install went well. Just for info you can buy the 250W version and reprogram to 350W - all it needs is a (custom) programming cable. The motors and controllers are the same and the motor then retains the 250W stamp on the casing for legal matters. Many other parameters can be adjusted as well, such as giving motor assistance throughout the cadence range even at lower power settings (instead of the assist being cut off at low pedal speeds when you choose low power settings) and also allowing full power assist when pedalling. By default the drive only provides partial assist when pedalling - you need to use the throttle for full power.I bought the 350W BBS01, as I wanted a little bit more than the legal 250W.
I wasn't sure if the 250/350 were the same unit with just differing firmware and since the price difference was minimal I picked the 350.Good to hear the install went well. Just for info you can buy the 250W version and reprogram to 350W - all it needs is a (custom) programming cable. The motors and controllers are the same and the motor then retains the 250W stamp on the casing for legal matters. Many other parameters can be adjusted as well, such as giving motor assistance throughout the cadence range even at lower power settings (instead of the assist being cut off at low pedal speeds when you choose low power settings) and also allowing full power assist when pedalling. By default the drive only provides partial assist when pedalling - you need to use the throttle for full power.
Michael
27mph!? That's quite a speed! I haven't finished my conversion yet (to a flat bar road bike) but I do have a programming cable so if you're ever around Guildford you're welcome to use it!I wasn't sure if the 250/350 were the same unit with just differing firmware and since the price difference was minimal I picked the 350.
I've left it as stock for now as I didn't want to invalidate the warranty.
I did notice the difference between WOT and PAS only, but have found the PAS level 7 keeps me ticking along the flat at 20mph in top gear.
I know I've got reserves, another 2 PAS levels and throttle if I need it.
On PAS 9 pedalling with a WOT I was getting 27mph up hill, so have dialed it back to save the battery and to be less conspicuous.
But I am keeping an eye out for a programming cable.
strictly for what it's worth, i just completed building an oxydrive kit (supposedly 350w but really 36V 18A max by controller) into a b'twin triban (all up weight in teh end is around 20kg) - i did a circuit including a very steep short hill and much longer relatively steep hill 9i'd groan in lowest gear up teh steep hill unassisted and jsut about really work to make teh elss steep one at around 6 mph iin a lowish gear).Fitting the kit was very straight forward. No hiccups what so ever.
I'd picked up a dremmel clone from LIDL ready to grind out the bottom bracket but it slid in effortless. The dremmel clone is still unused.
Couple of hours work as long as you've got the right tools to remove the cranks. If you're not sure about anything I found YouTube to be invaluable.
Quick zip tie of the cables for a test ride, which I've not changed after 400 miles.
Only pain was soldering a connector on the battery leads as the crimped ones in the kit didn't seem to match.
I'm very impressed with the kit, tending to just use the PAS now.
1st couple of times commuting to work it was very easy to use the throttle and overtake the roadies going up hills.
I like the kit because it makes me pedal all the time as I would have to do without it. It levels out the hills and makes it easy riding into headwinds and I still feel I'm getting a little of a work out.
It's easily knocked 5 minutes off my commute times. Using only PAS level 7, controller is unmodified.
I've no idea how it compares to hub motors as I've never tried them.
Hoping to use it much more when the weather improves.
the TCM motor you tested is powered by a 14A controller, your BPM is powered by an 18A controller, the BPM in the Big Bear by a 20A controller. That's why Woosh have put 20A controller in their Krieger (bigger TCM, the Krieger has the motor inverted, sitting above the downtube) to match the BPM raw power. That will even the playing field a bit. At the time the TCM was introduced, Hatti was totally convinced that it's illegal to power the motor with anything more than a 14A controller. If you compare the CD against other woosh bikes with 14A controller and SWX hub motor like the Gale or the Sirocco or the Santana, the CD will outrun any of them on any hill. The Krieger matches the Big Bear on pulling power, is quieter and faster if derestricted.strictly for what it's worth, i just completed building an oxydrive kit (supposedly 350w but really 36V 18A max by controller) into a b'twin triban (all up weight in teh end is around 20kg) - i did a circuit including a very steep short hill and much longer relatively steep hill 9i'd groan in lowest gear up teh steep hill unassisted and jsut about really work to make teh elss steep one at around 6 mph iin a lowish gear).
teh thing is i tried it back to back with a friend's 36V 18 A crank drive in a simialr kind of 20ish kg bike (TCM crank motor). i found a surprising result: the hub drive does both hills faster - perhaps one pedals marginally harder 9at least up teh very steep hill because im not entirely sure teh hub gear will restart from standstill), but with very similar effort teh hub gear does teh circuit severla minutes quicker. I'm not sure why thsi is and sincerely dopnt wish to start a dispute - logically id have thought a crank drive would be more efficient. I liked both and think both woudl be godo to own
Just checked strava, my average speed for the segment in question was 27.4 mph, were I remembered the figure from. But that did partly include a flat section before the hill.27mph!? That's quite a speed! I haven't finished my conversion yet (to a flat bar road bike) but I do have a programming cable so if you're ever around Guildford you're welcome to use it!
Michael
