Checking over the fluids, tyres, battery etc.. on the little Micra, I tested the voltage of the battery.
It had been charged fully the night before, but left overnight to settle. Think the outside temp wasn't much above freezing though.
The voltage read 11.8 volts, which I thought was a bit low. I tested with two different multimeters.
The car starts fine and the reading goes up to 14.5 volts when the car is running.
Does car battery resting voltage drop slightly when the battery is very cold and can anyone confirm whether 11.8 volts is ok, or should I think about replacing it soon?
