Do hub flange adapters to fit rims with a different numbers of holes exist?
3,246
Has anyone seen Polo mint shaped hub flange adapters with drilled holes, to fit say a 28H hub to a 32H rim? The inner 28H bolted onto the hub flange, the outer 32H spoked.
matthewslack
1,862
1,346
Entirely at your own comprehensively assessed risk, you could drill four extra holes in the hub, and accept slightly less than perfect symmetry in the spoke pattern. Two each side, 180 degrees apart, midway between existing holes.
Or make a complete set of new holes in the rim, aligned to maximise distance between your 28 and the existing 32.
Or change to a 32 spoke hub and rim.
Reactions: guerney
3,246
I would, but unfortunately hubs for 32H are very rare and fabricated from Unobtanium for 74mm wide Dahon fork droputs.
I was wondering how bad the outcome of drilling holes could possibly be. I have found three flange spoke hole adapters, for specific hubs. But nothing cheap and mass produced by the Chinese.
Seems the maximum width tyres my old Dahon can practically have is 2.125 inch. Was hoping to fit these Ryde Andra rims @Cadence brought to my attention on another thread, for up to 69mm wide tyres:
3,169
Seems the maximum width tyres my old Dahon can practically have is 2.125 inch. Was hoping to fit these Ryde Andra rims @Cadence brought to my attention on another thread:
What are you trying to achieve? Why don't you buy a new wheel, which would be cheaper? About £35 a pair on Aliexpress for disc ones if you want to convert, or get crappy rim brake ones.
matthewslack
1,862
1,346
Or find a CNC workshop that can make them to order. The first example shows the right design idea: the recess sits on the existing flange and is a close fit. Bolted through every old spoke hole for even load distribution.
Probably stainless steel rather than aluminium, to reduce fatigue risk.
It would be a one time adaptation, so a one off cost.
3,246
The option of fitting fatter tyres more easily on an ongoing basis, in the face of increasing rarity and diminishing range of hub flange hole options, for my Dahon's 130mm and 74mm dropouts. So far, I have found only two 32H hubs for 74mm, and one of them contains a daynamo - they're unicorn stools. These dudes probably don't deliver to the UK thanks to Brexit red tape, but of course I'll ask:
Just seemed a bit odd if there aren't cheapo Chinese flange spoke hole adapters. Perhaps I was searching wrong, hence my question.
thelarkbox
1,215
376
oxon
You can ebay ally plate, a ruler compass and sharp pencil should be all you need to draw an outline and hole pattern in card to validate first.. a few files a drill and a hacksaw and a few (lot off) winter evenings later ;)
3,246
Yes those do look good. With 144H, you've got 18, 24, 36 etc. possible holes, with 140H: 14, 20, 28.
I'll get a costing from a CNC outfit. It's just weird there aren't cheapo generic Chinese versions.
3,246
Yes it may come to that. Not looking forward to the day it becomes necessary, if it ever does. 2.125" wide should be enough for my Dahon Helios, unless poholes become even larger and deeper, which of course they will.
3,246
Bikes4two
1,009
433
Havant
The option of fitting fatter tyres more easily on an ongoing basis, ......
So what is the inner rim width of your current wheels and what width tyres are you hoping to fit?
Sheldon Brown 'says' tyre widths of 1.5 to 2x the inner rim width are fine but I've read in other places of 2.5x being ok too.
61048
Reactions: guerney
3,246
At the mo, I have 1.75" Schwalbe Marathon Plus safely (according to Schwalbe's chart below) installed in rims of 19mm inner rim width. 2.125" wide is possible. All of the dual walled Chinese rims on AliExpress have 16mm inner rim width or narrower, same or similar to the original Kinetix - my 1.75" wide tyres didn't look at all happy on those. Litepro seem to make good quality stuff, but it's a pity they only offer 16mm inner rim width 406 rims!
61049
3,246
Thanks for searching Saneagle. It isn't clear from the listing if they have 74mm and 130mm, they mention 100mm and 135mm... but I could buy those just for the 32H rims. I'd prefer dual walled for stability, I couldn't find any dual walled 406 rims on AliExpress with inner rim width wider than 16mm.
matthewslack
1,862
1,346
The difference in supported tyre width range from 16mm to 17mm rims in that diagram is remarkable!
I spent a week in the Alps years ago with 2.5 inch / 65mm tyres on 17mm rims. Survived.
3,246
All the more death defying because of course your tyres would have become even wider with lower atmospheric air pressure at Alp height. I don't think Schwalbe have a safety chart for that. They'd need one for mars colonisation, after they drop nukes over the poles to melt the ice caps, and make an artificial Van Allen belt.
3,246
I know @harrys converted his Dahon to disc brakes, on a thread somewhere, and now that @esuark has magically found 32H hubs for disc brakes on AliExpress (how!?? I can never find anything I'm looking for using AliExpress's unSearch engine!), a fat tyred disc braked Dahon Helios on wide Ryde Andra rims could be a viable option. Might just be the rear wheel, mind you @Sturmey converted his front fork to disc brake using an adapter too (or was it the rear? Can't recall. Deffo was a different adapter to @harrys).
3,169
use Google to search for them on Aliexpress. It understands what you want and searches for it, unlike the Aliexpress search that used to be good, but somehow they ruined it.
Reactions: esuark
3,246
I should have, but a sense of futility got to me. Things is, those bar steward merchants of cheap tat have stuffed every page with so many extraneous keywords, or advertisers have paid for too many keyword listings (sponsored ads are not marked on AliExpress), even Google is discombobulated. With this search just now, I had to trawl to Page four to find the first vaguely useful result! And is it a 32T 74mm hub? Hell no! I wondered if the AliExpress unSearch enine works better in Chinese, doubt it, tried that at one point.
