Hi all.
I had a post recently about my battery (18Ah) discharging when the bike was standing for a week or so. The battery indicators both in the display (LCD) and on the battery (LED) would jump from say 5 to 2, in one week without use. This happened three times in a period of one month, and then the problem stopped. Recharging the battery after those incidents was a bit strange, as the charge went normal until 2-3 LED's where reached, and then it finished with full charge and all LEDs went black.
About the same time I noticed another problem that took some time to reproduce accurately. When I use the backlight in the LCD display, and the charge indicators show 1 or 2 both on the battery and in the display, the assistance will suddenly cut out after some minutes riding with High assistance. The charge indicators in the display (LCD) then show no charge (no bars), however the battery LEDs (when button is pushed) show the same charge as they did before the incident.
When I turn the display off/on, the charge indicators in the display again indicate correctly (1-2 bars), and power is restored. If I keep the backlight off, the error does not occur. When I turn on the backlight in the LCD display again, it cuts out with "no assistance" within minutes. With charge indicating 3 or above, the problem does not seem to occur, even when the LCD backlight is on.
This error seems to occurs faster if battery is cold (outside temperature, 5-15 deg. C) than at room temperature (20-25 deg. C).
Kalkhoff in Germany sent me a new LCD module complete with wiring, but the problem persists with the new one. Now they say that it may be the engine itself, and that the bike will have to go to a dealer or to the factory. Since both are a long way from here, that would cost me a fortune, so I am reluctant to send in the bike.
I wonder could it be the battery? Any help on this would be greatly appreciated. Could someone with a similar bike test under the same circumstances perhaps?
I must add that the bike now has a total of 1407 km, and looks like new. It has never been ridden in the wet. Battery has been charged on a weekly basis, when LEDs are down to one. I use only the original charger. Bike is stored indoors all the time.
Regards,
Michael
Regards,
Michael
