Hi guys
To get the rear hub motor wheel to fit centrally in the frame I need to add 10mm washers to the non drive side.
Firstly I’m pretty sure stretching the dropout 10mm on one side won’t cause the aluminium frame any issues right?
Secondly doing the above moves the brake calliper away from the brake disc by about 3-5mm.
Do I add washers behind the disc so it lines up with the caliper? Or
Do I dish the wheel?
Is dishing better or adding washers better?
