Discharge test
I have two turnigy accucel 6 chargers
They discharge test at 1a max which is painfully slow
If I set both of them on the same pack it should discharge test at 2a I think? (1a each)
Is that right ? Or left ?
I think that you're in virgin territory there. I don't see why it shouldn't work.
I'm testing a brilliant laptop battery freebie in the bag I was given today by my local friendly laptop repair man - he have me 10batteries but this one contains lg 2800mah cells
They were all at 4.15v out if the pack. Great start :)
Discharging via both at present
Interestingly both at 0.4a (0.8v combined) forgot to say the chargers can only discharge at 0.5a on a 11.1v pack (1a on a 3.7v)
So seems to be faster but I have inexplicably lost 0.1a per charger .....
Just to confirm readings I repeated the test using one unit only
Got exactly the same results (well within 1% tolerenace)
So this does work
Are those charger the same electronics inside, just a different manufactures label/case ?
Yes - exactly the same software and capabilities
The only difference is the turnigy version is fan cooled and the IMAX is passive cooled by heat loss fins
